exhaust manifold broken bolts help
karayj
Im doing an engine swap and upon taking the exhaust manifold off the used engine becasue they are different then the originals so i was going o swap them with the old one I took off my blown engine 2 bolts broke the is about 1/2 inch that i can grab whats the best way to get it off i don't want to buy a new head after threw the old block out with the heads on it which i could use right now.. thansk to the wife staying on my back with the old when are you going to through out the old engine its an eye sore
Solittle
Re: exhaust manifold broken bolts help
Go to the red search at the top of the page & enter "broken bolt" sit back & read away.
Ralph 123
Go to www.sears.com and search for item number 00952152000<br /><br />Craftsman Drill Extractor <br />Drill-Out™ power extractors for extracting broken bolts and screws. The shortened length helps you control the tip with ease. 1/4 in. to 1/2 in., 6 mm to 12 mm.
snapperbait
PB Blaster.. Spray the busted bolts down with PB Blaster and just let it sit for a while (several minutes)... Just before you go back to remove them spray em' again... Get a set of ViceGrip's, tighten em' down real good and go for it...
If you don't have access to Oxy-Acl torches, Do as snapperbait says, Only After you've PBed the h*ll out of them,+ Locked the Vise-grips as Tight as you can, take a BFH and Whack them very Squarely on the ends, directly Into the heads....<br />Then try Turning...<br /><br />BTW, Throw the Ole' Lady Out, Not your Parts....<br />Atleast Not till you're project is Done.....
snapperbait
Bondo.. Good call on the "BFH" hammer... :D LOL.... The BFH is my favorite tool right next to the sawsall! :D
karayj
I DRILLED THEM OUT AND ONEI WAS ABLE TO TAP THE OTHE THE TAP BROKE INE THE HOLE SO I USE SOME PUDDY THAT TURNS TO METAL HOPEFULLY IS SEALS LIKE A GASKET AND IS QUITE WELL SEE....
