Exhaust Manifold Sealer or no sealer
Taz59
Changing the exhaust manifold & risers tomorrow if the weather stays dry,do I need to put any sealant on the exhaust manifold,
Cheers
Taz59
Re: Exhaust Manifold Sealer or no sealer
Permatex ultra copper not available in the UK :(
Ayuh,.... What gaskets ya usin',..??
I use the carbon metallic type, rather than the green paper style,...
Perfectly CLEAN castin's is Way more important than any sealers,...
I put mine together Clean, 'n dry,...
Taz59
Bought all origanal Volvo exhaust manifolds & risers they come with gaskets and studs and nuts.
bruceb58
Volvo has changed their gaskets and instructions a few times. The gasket kits almost always come with instructions. Didn't you get them?
Taz59
Yes got the instructions but the sealer is not available in the uk ??
bruceb58
Hard to believe there isn't an alternative or have it shipped.
dypcdiver
I am about to do a similar job on my engine, gaskets, risers and manifolds purchased a few weeks ago. On inspection I notice the instructions included with the riser gaskets are dated 2008 and specify no gasket sealer to be used!
After a long search for the recommended product I found loctite do the same product, but not in the UK. Nearest I can find is the link below.
Best of luck.
VHT COPPER CORK PAPER METAL -WATER PUMP SUMP HEAD GASKET - SEALER CEMENT SP21 | eBay
bruceb58
Instructions have changed since then.
Ayuh,.... So What sealer was specified, that ya can't get in the UK,..??
Is the Permatex line available,..?? if not, what is,..??
I don't do much at All with Volvos,...
Merc's carbon graphite gaskets go on Dry,...
Taz59
This is from the instructions that come with the risers
Change to Procedure:
Before installing a riser gasket, coat the mating surfaces of
both the manifold and the riser with a copper-based, heatresistant
gasket compound.
Examples:
Permatex Copper Spray-a-Gasket? (80697)
K&W Copper Coat? (401612)
Aerosol or brush-on applications are both acceptable.
gasket compound.
Examples:
Ok, so they want a copper based sealant,....
What's available on yer side of the pond,..??
I'd have thought Permatex would be,....
Taz59
nothing available so my son has a mate who lives in LA so he is going to send us some over
dypcdiver
Didn't the link I posted work? It is already in the UK and sounds like the same product as the Permatex. I checked the MSDS and they both seem to be very similar in content.
Taz59
I have ordered from eBay,but my local Volvo dealer is looking into the matter,will keep you posted
