Exhaust manifold swap 5.7 Mercruiser
J. Mark
I am restoring a 1988 Marlin Ski Magnum. The boat is an inboard and I have it stripped to the hull and am going through everything as the boat was not running when I got it.
The exhaust manifolds look good, but the risers are looking kind of rough. I have not been able to locate a local shop to pressure test the manifolds.
I have potential access to Indmar exhaust manifolds and though the risers are shaped differently, my exhaust is being replaced and I have plenty of clearance under the doghouse, so that is not an issue.
Is there something I am failing to consider?
If the indmar parts source falls through I had also considered using Volvo exhaust manifolds. Again is there anything I am missing about the parts interchangeability?
Engine rebuild is almost done and I need to line up the next round of parts to keep this restore moving.
mylesm260
Re: Exhaust manifold swap 5.7 Mercruiser
I am by no means an expert...but....
The manifolds bolt the engine, the risers bolt to the tops of the manifolds....
The Y Pipe bolts to transom plate.
In order for everything to work, the Risers have to match up to the Y Pipe.
If you start mixing and matching exhaust components, you will likely run into a situation where the risers no longer match up to the Y pipe, and you will no longer be able to couple the two together.
The Y-pipe is not flexable or bendable, so if the outlets of your risers don't end up directly infront of the Y-pipes, your screwed.
Buttanic
He said it's inboard so it shouldn't have a Y pipe.
Buttanic
If he has a V-6 or V-8 he has a "Y" pipe in the exhaust. (Unless its through the hull.) As he says manifolds (plural) I assume its a V engine.
Since it's a ski boat I'm pretty sure he is referring to a straight inboard not an I/O and most ski boats have dual through hull exhaust.
Ayuh,.....
Most of the Inboard Ski boats I've run across run down,+ Out the back,... 2 pipes, 1 each side....
Sometimes they might have a water muffler, but usually just thru-hull at the waterline...
So,.. That Said,... That's what I happen to read out of the OP's question....
I would say you can run Any set of manifolds,+ risers that you want too....
They're ALL just abit Different than each other,+ you'll just have to adapt the rest of the exhaust to match up...
There'll be mounting bolt Holes on some,+ others won't...
Some will dump out at 3",.. Some at 4",.. Some at 3, 1/2",... Some at 2, 1/2"...
J. Mark
No y pipe, it is an inboard and runs dual exhaust through silencers and out the hull.
3" set up currently and I am going to stick with that.
Sounds like I have a few options and that other than the 3" softwall hose length and angle being slightly different, a number of manifold kits will work.
Gotta love the versatility of that chevy small block 350 set up. I always liked ford motors in my play cars, but the chevy really is easier to deal with on the parts front!
J. Mark
oh and as to the substitute for pressure testing. . . I have a gallon of acetone, waste rubber hose and clamps and I have already had the manifolds dipped in an acid bath and cleaned out thoroughly (even had them freshly painted) My neighbor is a welder and owes me 13 dozen favors so he does a lot of stuff for free! You should see the new pylon brace we designed and he welded up . . . as soon as I can I'll post some pics of it.
Thanks for the link and the tip, it makes perfect sense. Wish I had a borescope, but I have dental mirrors to look inside at least
He makes some beautiful bimini top type frames too. John is an outstanding welder (and a good neighbor too-just don't lend him your best chainsaw!)
