1999 Mercruiser 5.0L A1/G2
Started and warmed up starboard engine to operating temp in the water noted one exhaust manifold and riser warm to the touch and the other was noticably cooler. Is the normal? Been having intermittent cooling problems on this engine. Impeller changed prior to this season. Has had T-stat changed 2x recently.
The Port engine same sequence as above both manifolds&riser are cool.
Planning on removing the warmer riser to have a look for restriction....is this the way to go??? is there any other advice??
Thanks
Pete
Thanks
Pete
