Re: Exhaust Manifold Torque Numbers
Bolt torque is determined more by the grade of steel used in the bolt/stud than the needs of the particular application. If the application needed more torque then a better or bigger bolt is spec'd.<br /><br />In 1987 most bolts on the market were grade 2 plated; 20 ft lbs was called for in manuals that were based on that reality. Nowadays most bolts are grade 5, and 30 to 35 pounds is fine for a 3/8 diameter bolt.<br /><br />"About that tight" will work in most cases, especially if you are willing to go back and re-tighten after initial warm-ups.
