Joker757
- May 13, 2009
- 134
Hello fellow boaters. I'm new to the site. I have a question regarding the manifold, risers and elbows on my 1999 Maxum 2800SCR. The boat sat for about 8 months and I recently started getting it ready for the season. After changing the oil and filter, thermostat and turning by had a few times I started the engine. I let it idle for about 20mins. I then pushed it up to 3000 RPMs and the temp started going up to about 180 and the alarm eventually went off slightly before 200. I shut down and let it cool down. By the way the boat is on a trailer and I used muffs. I reved it up again and same result. Went back to idle and the temp immediatly went down. From experience this was indicative of a blockage of the exaust cooling passages. I reved it once more and noticed that the water flow out of the stern was now much more volume and about 2 to 3 teaspoons of rust particles ejected. Now when I run it up it stays cool and runs quite and smooth. Just to be safe I decided to pull the risers and elbow. They have some rust inside but aren't blocked. Water jacket walls look don't look thin. These risers and elbows are about 2 years old. Should I clean them or leave them as is? I do plan on replaceing them next year but was hoping to get at least one more season out of them. If I'm to clean them what's the best/safest method? Your thoughts?
