Exhaust manifolds
ROGNE
Hey there I've got a 1976 ford 302 190hp with the original omc exhaust manifolds on it and would like to find new ones the exact same but I can not seem to be able to find them the ones that look exactly like the ones on mine are saying there for a small block Gm I'm thinking maybe some one who reads what I am asking here will be kind enough to help me find what I need thank you
ROGNE
Tried to send you a pic but it didn't work for some reason I'm going to say rear risers
ROGNE
Not quite sure why it says I am sending you this message at 10:51pm time it's only 8:30pm and so sorry if this is the correct time where you are at
jbcurt00
Best to ask this here, ROGNE, rather then over in REDRIGS 2+yr old topic:
Your the best that is the exact set up on my motor you don't know how much I appreciate your time and your information and let me tell you I'm a put together by picture so outstanding thank you again if you don't mind me asking where do you think I could find that hole set up right here on iBoats
Pix help
http://forums.iboats.com/forum/forum...pload-tutorial
If you dont have your iboats profile setup for DST and your timezone setup, your post times arent displayed correctly.
Go down to the OMC (FORD) V8-302 and 351 C.I.D section for the log style manifolds. That will get you the Barr part numbers
http://www.barrmarine.net/omc.html
ROGNE, Did you check the site Bruce posted?
Redrig
Master Chief Petty Officer
So if you have the rear risers , you are NOT going to find any that are new , well you might but you will also pay a fortune for them . Your only choice is to convert to either bananas or the center riser conversion . I wouldn't trust any ebay used manifolds , but that's just me .
I would go with the centers risers for sure .
There are "conversion kits" that you can buy that have everything needed and converting over is fairly straight forward as I laid out in my thread .
here is the parts list right here on iboats .
http://www.iboats.com/Universal-For...8064300--session_id.978344482--view_id.272956
