I did a once-over on my motor (125 ELPTO, 1998), and I noticed something either new or something I have not noticed before. I'm not sure what cover this is (see below), but there may be some sort of "crack" going completely across it. I'm not sure if you can see it clearly, but there are some scrape marks I made by the "crack" to determine it's depth/impact. There is no gap in the "crack" and the "crack" goes directly behind the sticker. The sticker looks to be in perfect shape, so it doesn't appear anything is leaking out of the "crack". The paint looks to be intact along the whole "crack" save the spots I tried scraping it off.
I had the motor out just last weekend, and it ran great. The impeller was new last year and only run a handful of times. The motor doesn't seem to get too hot, and I don't get any exhaust to speak of.
Is this something to worry about, or just some minor imperfection of the manufacturing process? The plugs are all clean (save a little bit of oil, which I believe is normal). Anything else to look for?
Thanks!
Thanks!
