Exhaust plate removal...
ZmOz
Trying to remove the exhaust plate from my '74 1500. (is that what it's called?) There's about a billion 1/2" bolts to remove, and they are coming out just fine. In the top corner there is one 9/16" bolt that won't budge. I actually broke my socket wrench on it. My impact wrench has no effect on it. What the heck?!? How do I get it out, and why is it stuck in there so good?
emckelvy
Re: Exhaust plate removal...
If you're talking about the cover on the port side of the motor, that's the outer exhaust manifold cover.<br /><br />All of the bolts in this cover are supposed to be 5/16"-NC, with a 1/2" bolt head. The 9/16" bolt-head sounds like it'd be a 3/8" thread, definitely not supposed to be there!<br /><br />Likely someone broke the bolt in the past, and rather than fix it the correct way (drill out the broken stainless nub and install a 5/16" Heli-Coil), they tapped it out to 3/8". Very Tacky! <br /><br />Maybe they even used some JB-Weld (or similar glue)in there to hold it in place, and that's why you're having fits trying to get it out.<br /><br />Probably the only thing that'll loosen it up is heat. If you have a propane torch, that'd be the safest. Oxy-Acetyl outfit you must be very careful not to melt the alum block!<br /><br />Worse come worse, drill the bolt head off and remove the manifold. You should have better access to the bolt nubbin at that point.<br /><br />Be sure you check the inner exhaust port water jacket cover for leaks/erosion.<br /><br />When you reinstall the new exhaust cover/gaskets, be sure to use a bit of anti-sieze or Permatex #3 gasket dressing on the bolts to prevent future sieze-ups. Also torque the bolts to specs. This is a very critical part of the repair, if the cover is not torqued properly, the potential for a gasket leak is increased greatly.<br /><br />HTH...........ed
ZmOz
Great...I was worried it wasn't supposed to be there. :rolleyes: It isn't painted like the rest of them either. Hmmmmm.... :mad:
ZmOz
Alright, I heated it with my torch and turned the pressure on my impact wrench to 130psi. :) Finally came out...looks like somebody just jambed a bigger bolt in there... :rolleyes:
andrewkafp
ZM<br /><br />You re-building that tower ? Or just using it for parts ? When does your summer start over there, and will you be back on the water by then ?
ZmOz
Still haven't decided whether I will rebuild it or not. All the parts are good except the cylinders and pistons. :) I thought I was getting another in good condition for $400, but that's looking less and less likely, the seller is extremely hard to work with. :rolleyes: Clams is offering me a pretty good deal on rebuilding it, and it would be pretty nice to have a like new motor. :) Late May/early June is about when I can start boating, although we have already had several days in the upper 70's that I could have gone out. I went to the boat ramp to eat my lunch one of those nice days...almost cried because I couldn't go out! :(
andrewkafp
ZMOZ
L O L.. :D <br /><br />At least OB's and parts are affordable over there.<br />A running TOP like yours would go for 3-4 times that (about $1500US) here .. and they are also as rare as hen's teeth. :( <br /><br />BTW Clams would have to do a good job for you being a fellow iboater.. Tried to get him to move over here but he was content on staying there.
ZmOz
They normally go for around $1000 or more around here...that was just a really good deal I was getting. :)
