I was just speculating, reasons I might have power loss or what seems to be power loss. I was only turning 4k at WOT, and I have checked almost Everthing. My problem is I haven't ran this boat and motor for along time and can't remember how much power and how fast it should be.
As in your other thread, we need to determine if the tach is reading correctly. Also need to determine if your prop is correct for the boat and load it's carrying. Check the easy stuff before you start tearing into the motor...
prop is a 13 pitch load is pretty heavy two 6 gallon fuel tanks and gear with myself at 300lbs. as far as the tach how do I determine it is reading correctly?
