jumpjets
- Nov 11, 2010
- 313
I have read here on iboats that the Merc exhaust system should be periodically replaced. I pulled apart my exhaust system to inspect it, and I am not sure if I need to replace it or not. I have an open cooling system, and I primarily boat in the ocean, or very brackish rivers within 20 miles of the ocean.
This is the port side riser inlet. Considering I've been boating in salt water for the last 3 years, I though it would look worse. How is this comparable to others that you experts have seen? Does it need to be replaced? Should I just take it to a machine shop and have them soak and clean it? Should I just reinstall it as is after I clean it up at home? The other riser looks exactly the same.
More pics coming in follow-on posts....
