2002 merc 5.0 mpi. I changed exhaust using Barr parts 3 years ago. I see rust behind risers on tops of manifolds so I think the risers are leaking at high speed and want to fix it before putting boat in the water. Can anyone think of something special to look for? I have read bad things about never seize on marine parts. Should I put some grease on the threads? I am planning to remove studs to get risers off and then reuse studs. Thank you. RR
