magic11305
- Jul 18, 2009
- 53
I have a 5.7 vortec I pulled and rebuilt. When test running on the engine cradle, I hook a hose to the water intake that would normally attach to the water tube at the transom. The engine runs what appears to be normal temp and the thermostat is new and working properly. This engine has water bypass so that water is introduced into the exhaust before the thermostat opens. Probably too much information for the simple question I have. A lot more water comes out of the starboard exhaust than the port. I was wondering if this is normal? All the gaskets on the manifold risers are clean and new. The specs for this engine called for restrictor gaskets which I insalled. When I reassembled the engine I made sure to clean all water passages and hoses. The port riser does get a little warmer than the other but no too hot to leave your hand on it. Any thoughts?
