expected speed from 85 hp on a 16' 1976 Ebbtide
SCStripers
Its a fiberglass bass boat style and i am would like to know how fast I should expect this boat to go on the water, 12 3/4 prop i think, thanks
Jack Shellac
Re: expected speed from 85 hp on a 16' 1976 Ebbtide
For an 85 HP, 12 3/4 sounds like the prop diameter. What is the pitch of the prop and how many RPM's does your motor turn at full throttle? This info will help calculate top speed. OR. how much does your boat weigh when you are loaded up for fishing and what kind of hull--deep-V, semi-V or whatever? Is motor an OMC?
SCStripers
Here are the specs on the prop, 12 3/4 x 22. Fiber glass boat, not sure of the weight. the hull is V but does have a liking of a tri hull. Motor is a OMC. I have no tachometer so i have no clue what the rpms are..........Not much help am I
Jack Shellac
Well, guessing the weight of your boat at 1200 lbs, you should get about 40 MPH.
