Expert advice needed-120 Merc - u-joint/coupler prob.? -
tjaizmopars
1975 Galaxy 16ft 120 Merc. I/O -, when purchased seller said outboard coupler was bad , put water muffs on and ran for maybe 5 min,fwd & rev seemed to work fine,then prop quit spinning & temp started to rise-shut it off then -does this sound like coupler/u-joint assy.?- unit did not make any loud or unusual noises while running but when prop started to slow smelled a little funny-to change this assy. - pull motor or pull outboard,or any other troubleshooting needed -all expert advice greatly appreciated.<br />Thanks TJ
horndog
Re: Expert advice needed-120 Merc - u-joint/coupler prob.? -
without seeing it and what it is doing its hard to tell. Sounds like something spun in there and its probably the drive shaft
Trent
Very common problem. Pull the engine to replace the coupler. Also pull the outdrive. You need to check engine alignment after you install a new coupler. Check rear engine mounts for sagging. Boat that old will have sagging mounts which is the number one cause of coupler failure.<br /><br /> Coupler
Classic Symptoms....<br /> seller said outboard coupler was bad <br />A Sure Sign.... <br />then prop quit spinning <br />Makes sence...<br /> temp started to rise <br />Yep, Waterpump isn't turning anymore....<br /> smelled a little funny <br />Burning Rubber ????<br />Like Trent says, Pull'm Both... It's Really not that bad a job....
