Bigprairie1
- Jun 13, 2007
- 2,568
Ok, I have a '72 Chev 1/2 ton with the original Rochester Quadrajet on it and I have started doing some tuning on the carb and I'm curious if anybody has any good tips on setting this carb up to best running.
First: Jet adjustment? I've heard that most of these always use...2? turns out from lightly seated as the initial adjustment (do I have that right?)
Second: The truck came from and spend pretty much all its life in Auburn, California (pretty close to Reno and at about an Elevation of approx. 1500-2000 feet above sea level). Would this elevation have required changing the jets on this carb from a sea-level application? (I don't know when this issue starts to kick in on these things). I'm at sea level here so although the truck runs well I want to make sure I have everything at its best.
Anyways the backstory is that a few of you may remember I bought a classic truck a couple of months ago out of California. The truck is a '72 Chev 1/2ton. Well I finally got it home (late) mostly due to business commitments.
It's a really nice original truck.....tight, dry, straight and a really good driver. It has a 350/4bbl-TH350 in it and I'm looking forward to doing my own tune on it and sprucing up a couple (very) minor things then using it as a reasonably regular driver.
If any of you guys (gals?) can offer some insight on tuning up this puppy a little further It would be much appreciated.
Many Thanks!!
BP
Many Thanks!!
BP
