Yes, fun. another oil fill question....
I have a yamaha 200, I do not have a tilt sensor. my reserve tank suddenly does not refill. This is second time since new in 2004. first repair I switched level sensors in reserve and problem went away. This time when first failed emergency fill did not pump oil. had to hand fill in rough waters 4 times to get in. spent several hours with meter checking voltages. weird thing. removed vent line from reserve and emergency tank filled. ran boat in cradle for 30 min at 3000 rpm. NP. Let her down and ran the bayou. pump seems to keep up until running wot. At this rpm I tilt engine to trim for speed and handling. still within tilt range (not in raise mode). Clogged filter? or is there an interlock for the tilt angle? I do not have a set of schematics to look at. I am a instrument controls designer. I look at the logic and the level guage is doing its bit. high high causes pump to stop, low low drops rpm and causes alarm. Rpms over 4000 oil just can't keep up. (this is not documented well. any thoughts, do you have a schematic. this is a 2004. had a workmate suggest running "seafoam" through tank to clean out pump...
what more do you know about the tilt lock out, if that is malfunctioning then i am chasing my tail everywhere else.
read a post mentioning tilt sensor locking out fill. played whole game and understand system as best as possible without wiring schematic. Pump runs. Emergency pump DID not work until vent tube was removed. Handled every wire in motor, plus boat is CC we take offshore, so she takes a beating. suddenly emergency pump works. level sensor in tank inhibits overfill, signals low low level with alarm and 2000 rpm drop. Oil appears to keep up until we run wide open. this involves TILTING the motor to lift hull. Ran the boat on cradle in water then for an hour or so on water, starts stops turns multiple rpm ranges.
ahhhhh.........
does anybody have a schematic!
2004 200hp Offshore. could be filter in line to tank, but intermittent failure drives me nuts. Tank installed in impossible place. Would prefer to test everything else BEFORE i pull that tank.
there is an interlock somewhere that
is causing the main tank pump to cut off.
ahhhhh.........
