External Wiring Harness
kax2000
Where can I get a external wiring harness for 1964 merc 850?
GA_Boater
GA_Boater
Re: External Wiring Harness
Look at this I just grabbed a Merc 850. Pick the year and right serial no. range for your 850, but I think they are the same. It gives the Mercury internal no., but that's all you need because I don't think Mercury doesn't make them any more. The CDI catalog page I posted has all the OEM to CDI info you need. Hope this helps.
ThumbPkr
I think that iboats sells them in their store if you want to support the website here.Ron G
Faztbullet
You will likely need to change the internal harness to match the control harness as a 1964 850 should be a 6 cylinder.....
