Hi guys & gals
Attatched is a picture of what happens when a tach cable shorts out.
This is on a 95 Honda BF25 with tiller steering. The tach is a Tiny Tach self contained unit. I want to stress this was an installlation mistake. The tach has 2 leads, one wrappes around one of the spark plug wires, the other to engine ground. The Tach it's self operated perfectly.
So 71 hours of run time ago, I installed the cable by making another hole in the grommett were the cables pass into the engine. I passed the Tach cable through this hole and tie wrapped the coaxle cable from the tach to the throttle cables to keep it out of the way, bad move, my guess is the tach cable insulation got crushed at the tie wrappes & either shorted internally or to the throttle cables themselves.
Looks like about $100.00 in parts so I guess it could have been worse.
