JASinIL2006
- Feb 10, 2012
- 5,738
I'm replacing the impeller in my Alpha One Gen 2 outdrive, following the instructions put together by Don S. that I found up in the stickies. I've also watched a couple of Youtube videos of the procedure.
I have the drive split and I've removed the old impeller parts. The old impeller looked a bit beat up:
Anyway, everything is looking about like the instructions indicate. In my impeller kit, though, I seem to have a part that's not mentioned in the instructions, nor was it mentioned in any of the videos I watched. This is what it looks like:
According to a parts catalog, it is something called a carrier assembly, but I can't figure what I do with it or how it is installed. It seems to sit beneath the faceplate of the water pump, but I have no idea if I should remove the old one (or how it comes out) or if I should just ignore it and assemble the parts that are mentioned.
Anyone know what this thing does, and whether I should mess with it?
Thanks,
Jim
Thanks,
Jim
