woodrow2929
- Sep 29, 2016
- 41
So I have installed an transom tilt trim switch on my 1989 50hp force and basically I had spliced into the blue and green cables that are running up to the one built into my remote handle, my question or concern is the power cable (which in my case was purple color) is it safe or ok to put it directly onto the battery via a ring terminal? Or even the ring terminal that feeds my fuse block? Because I do plan on adding a blinker style trim on my steering column as well.
thanks!
thanks!
