I have a 1990 Rude 115. I was recently towed in b/c the motor was running at 5-6k RPM's in neutral/forward, and reverse without any throttle. My intial thought was a throttle cable problem, or broken linkage, or stuck throttle on the motor. Everything seems to be in working order to the "eye". Is there a "fuel sensor or regulator" that may need replacement to allow my motor to run at normal rpm's when idling? Any other thoughts are also appreciated. Thanks.
