Eye bolt for flywheel 1988 mercury 70 hp
Slamcity
Hi Guys,
Does anyone know what size eyebolt I need to lift up the motor with a engine lift thru the flywheel?
gm280
:welcome: Slamcity to iboats...
I seem to remember reading this question a few times on these forums. However, Does you flywheel have the usual three threaded holes in it for a flywheel puller? If so, you can use those holes to lift the engine. Just get a plate or something and bolt it to those three holes and lift away. The actual center threaded holes can be used as well. But unless you know the exact thread size and diameter, It would be a lot harder to rig up. I am sure someone will chime in with the actual size you would need. JMHO
