F 100 oil filters and other service recommendations
jamesppp
Hi, I have an F-100 mfg'd in 3/99. I bought it new in 9/99. Im not sure if it is a 99 or 2000 model. Can anyone tell me the correct part number for the oil filter?
I have filters with 2 different part numbers. Both will fit fine but Im worried that one may have a drain back valve, or not ..I dont know if it is supposed to.
Ive always changed fluids, checked plugs, belt tension etc. Im sure I need to have some other stuff done but the motor did great on my annual Florida trip last week
Any advice and does anyone know the correct filter number?
Thanks,
Jamesp
rodbolt
Re: F 100 oil filters and other service recommendations
the 99 and 2000 production runs used different oil filters.
post your full model number.
jamesppp
Thanks,
From the Serial number Plate: F1000TLRX
67F L 303667
U
I appreciate the help
Jamesppp
rodbolt
it is indeed a 99 model.
correct oil filter is 3FV-13440-10-00.
jamesppp
Thank you sir!
Could you recommend a service manual? Is there a manual specific to the F80, F 100 models?
I might as well get one and see if if I can replace the water pump impeller and associated parts for good measure. It is 10 years old now.
Jamesppp
