F115 losses power in rough seas
fpengr
Have a 2002 F115 with 530 hours service. Engine functions perfectly at all times except as follows: While runing at any cruising speed when the boat encounters a hard jolt, such a going though a large wake, the engine will loss power at the instant of the "jarring". Power loss continues with a drop in rpm until the throttle is returned to idle and reapplied. Engine will run perfect until the next jarring chop (when the same thing occurs). Power loss does not feel or sound like a specific electrical miss, is fairly smooth like the ignition timing is being drastically retarded or the engine is starving of fuel. Squeezing the fuel line primer bulb has not affect. No alarms sound during the power loss, no trouble codes are set in the ECM (per checking with a 12 volt test lamp per the service manual). Have cleaned the engine mounted fuel filter, installed a Racor water sepeperating fuel filters for outboards, replaced plugs, taken apart each electrical conntector on the engine, inspected (all corossion free), cleaned with CRC, and reassembled with contact grease. Pump fuel tank empty of all fuel at the start of each season and use only BP premium fuel from a trusted high volume station, use Lucus top cyclinder lubricant and fuel injector cleaner continously. Really feel the problem is electrical in nature in the engine management side. Interesting, my brother's carberated Yam 40 HP 2-stroke developed the same problem, his dealer's shop suspected it was the "power pack", he traded it in verses having it repaired. Hate to gamble with replacing that $900 part unless I am sure that is what it is. Any help or suggestions would really be appreciated.
erniefish
Re: F115 losses power in rough seas
how about fuel pick/up or primer bulb? just my first thought
Mas
Rough seas can stir up sediments in the fuel system. Are you certain all is clear?
MAS
