Hello! I spoke with Yamaha today and they suggested that I use the EFI Fogging Oil (the type you mix with gas) and run it through my motor as opposed to using any kind of fogging spray. I was told it is as simple as hooking a small, portable gas tank to the fuel/water separator and running the motor for a few... Unfortunately, I do not believe that my 2005 Ranger Reata 1850VS came with a fule/water separator....
Looking at how the fuel lines from the F150 and 9hp kicker are rigged, it appears that both motor's fuel lines "T" into a feed straight from the tank. Now, I like the idea of running some fooging oil/gas mixture through the motor as opposed to spraying anything into the spark plug holes and intake, but I do not see how I can make this a simple venture.
Any suggestions???
Thank you!
Andy
Any suggestions???
Thank you!
Andy
