F200 electrical failure
briggs
I had an electrical failure ,while running no warnig singles. the motor just stopped. all gages were dead no trim and no power to the starter. after about 20min the power returned. I ran for 10 min and it fail again. back on the kicker. after about 30min power came back ran the engine started but when the boat was on plane it started to die the next 2 hours at I was able to run at displacment seed. under 2400RPM. If anyone has had this problem i sure could use somehelp to figure out what is wrong.
2002 F-200 450 hours Thanks Briggs:
rodbolt
Re: F200 electrical failure
carefully check your battery cable connections, look for any splices in the cables, inspect the cable connections on the engine, inspect any battery switch connections.
you have a hull issue most likly, that engine not only uses 12V for fuel system it has a 12V ign system as well.
briggs
Thanks rodbolt, While on the water I by passed the three way battery swicth. No help I did have elec power to everyting ( GPS< SOUNDER ECT> ) but not the motor and its gages.
briggs
I have checked all wiring,and found no lose wires , no corosion and ran the motor for one hour. I can't get it to fail now. I'm losing all confidence in the motor.
briggs
the boat shop found a falty heat sensor in the motor.
rodbolt
you still have a problem the thermosensor nor the over temp switches have anything to do with electrical failures, they simply dont.
never seen a failed thermosensor on the F 200/225. can you mail it to me ?
