Re: F225 rough idle
Answer Rodbolt's questions and also have a leakdown test done by a QUALIFIED tech. I've found many F200-225 4-strokes get carboned up valves and rings from extended low speed running, especially during break-in, and from not using the recommended dose of Yamaha Ring Free. The leakdown test will probably show several cylinders with high leakdown rates thru the rings or intake valves. <br /><br />The factory recommended fix is to run two 6 gallon tanks of gas using the "shock treatment" mixture of Ring Free, 2 (yes, two) oz. per gallon of gasoline. One 12 oz. bottle per tank. Run the motor at all speeds, allowing shut down time for soaking the additive into the carbon buildup. Then change oil, filter, and plugs. If everything else is correct, your motor should run like it should.
