Hi guys,<br /><br />i have a 60 hp 4stroke carbed 2003 outboard that has a problem starting. I took out emergency kill switch and checked operation of the starter motor. When it worked fine, gear would come up and continue to turn engine fly wheel. Every third or fourth time i did this the gear would go up and turn the flywheel for a brief second and then fall down and continue to free spin below fly wheel. This is what happens on the water.<br />This motor has done this since new. It has only done 70 hrs. As it only does it now and again,they have trouble finding the fault at the shop. It now does it about 20% of times i begin to start it. After it fails, i try again immediately and it always starts.<br /><br />They have checked the pinion gear and checked all connections and batteries. It may be time to get them to pull the starter motor off.<br /><br />Any suggestions? ? solenoid<br /><br />Regards<br /><br />Kellaig
