bluewaterboater
- Apr 24, 2011
- 37
I have a 1999 Sea Ray 190 Signature Bow rider and lately I've been having some issues with over reving and popping sounds. I posted my motor issues in another thread and have been getting great help. After a tune up and some other positive results the prop size was mentioned in the thread. I bought the boat a few months ago and I'm still getting to know it I also thought it had the factory prop. After some research I am now confused.
This is what I have: 4.3l EFI 210hp with Alpha 1 drive gear ratio 1:81 with a Vengance SS prop 4816318 21p
According to the Sea Ray site my boat should have a 1:62 Alpha 1 with a 14 x 19 SS Vengance.
It shows that the NON EFI 190hp version should have a 1:81 Alpha 1 with a 14 x 23 AL - Black Max.
My boat has 169 hours on it. Is it possible that they made different gear ratios or did someone change my outdrive? Does it matter? What prop should I use?
Right now I can go over 4800 WOT and my tach goes crazy bouncing all over the place and I get a popping noise in the engine until I throttle back. I have more throttle available after 4800 rpms.
Thanks for any help you can give!
