Fan belt replacement
Marvan
On my 1971 Gulfstream 165 I/L6 Stock. The fan belt is falling apart, is there a easy way of changing it?
Re: Fan belt replacement
Ayuh,...
Remove the 2 bolts on the portside of the front motor mount,... Then the spacer block will come out...
Remove the old belt,+ install the New 1,...
Then replace the spacer block,+ the bolts you removed...
Bt Doctur
And while you that far, install a second belt as a emergancy spare safely tied out of the way. This way you wont have to remove anything to chage the belt is it should break again.
rockyman
i dont know if there is a difference between a 1978 and 1971 or not but i just changed my belt and went through the same steps but i still had to raise the motor up about 1/2 in. to allow for the belt to slide through the space between the housing and the motor mount.
Marvan
Thanks for info, what kind of belt is it? Sometimes I can order parts a chevy but the one they give me dosen't fit. That sounds real easy, and that second belt. WOW great idea...
rockyman
the inline 6cyl motor is the same as the 250 chevy truck motor
Marvan
Ya thats what I thougth and would call in parts for, but this measures to small. Maybe they look up the wrong one.
rockyman
could it be that one your replacing is strecthed a little and the new one is actually the right one after all ?
Marvan
Sorry a new item was put on the Honey-do list..They said thats is the right belt for a 250 I'll try it after buying a second one, thanks
