FAQ, Shift cable and Switch cutout switch adjustment, draft.
achris
More fish than mountain goat
Hi to all Mercsperts,<br /><br />We are getting a lot of questions about this subject. I would like to propose that we setup an FAQ for it. I saw an excellent theory of ops written by Qystan on the 27th June and with his permission would like to have it entered here.<br /><br /> http://www.iboats.com/cgi-bin/ubb/ultimatebb.cgi?ubb=get_topic;f=24;t=006998 <br /><br /><br />Comments please gentlemen,<br /><br />Chris...............
Fishermark
Re: FAQ, Shift cable and Switch cutout switch adjustment, draft.
I read the post you refer to, and it is indeed helpful. To a point. It clears up the theory behind the need for the cutout switch, but says nothing about the "HOW TO" of adjusting it. I usually refer people to another site which has step by step instructions on how to adjust the cable. It would be great if we had a post like that here in the archives that could be refered to. (With pictures of course! :) )
qystan
Achris<br /> Glad you found it useful. I have no problems with it going into an FAQ. Avoids having to keep reposting the same.<br /><br />Fishermark<br /> Main reason I did not try to describe the how-to is that there are many web articles available and manuals do provide quite good write ups. From my experience, I found that the procedure needs some tweaking. Unfortunately its not cut and dried. I finally managed to get it right after understanding the operation. I believe most be able to do the same if they understood how it works, hence the reason for the information than a step by step which needs to cover all the "tweak this if that" variations. Maybe, I could work on a flowchart, but it'll probably turn into a cobweb instead. ;-p
Fishermark
Yeah Chris, the post you listed with the proceedure is what I am talking about. Looks good! <br /><br />
Qystan, sounds like what I would wind up with! :p
achris
Ok guys, how do we get it submitted now? I'll do another post with the sections in it.
achris
Mercruiser MC-1, R, MR, Alpha One, Gen II shift system<br /><br />Many people ask about the shift cable setup and the shift cutout switch. Here is an explanation of how it all works and how to set them up. This will assume that there are no ongoing problems, like stiff cables or excess slack in the shift system. <br /><br />Theory of operation<br /><br />(Courtesy of "Qystan")<br /><br />The shift cutout switch "can" work in both going into gear and out. Let me explain.<br /><br />If you study the intermediate shift plate and the linkage. The function it performs is for the upper shift cable to move the lower (both directions) and allow one to move independently of the other. When independent movements occur, the shift cutout swich will sense this and cause the ignition to be cutoff, ignition is restored when the cables synchronise.<br /><br />So how does this work? The gear design allows shifting into gear quite easily, hence engaging gears is usually not a problem and the 2 cable movements stay synchronised during the engagement cycle, the switch is never actuated. If you have a sticky lower cable, the upper cable movement will result in an out of sync situation if the lower cable does not move. The switch will be actuated and kills the engine.<br /><br />Shifting out is slightly different, due to the gear undercut, the gears do not disengage easily. This will always result in non movement of the lower cable and actuating the switch. When the engine 'dies' the torque on the gears which holds them together is removed, allowing the gears to disengage. In disengaging, the lower cable moves and synchronises with the upper cable, resets the switch, restores ignition.<br /><br />Bad cable adjustments which misaligns the upper and lower cable neutral position will cause engine dying during engaging shifts. The misalignment gives an upper cable 'overtravel' which the lower cable cannot synchronise due to its limited travel. Symptoms would be engine dying going into gear in one direction but the other is ok.<br /><br /><br />Adjustment of the cables<br /><br />1. Remove both the shift cable (to leg) and the control cable (from control box) from the shift plate.<br />2. Push in on the end of the cable and have someone turn the prop slowly Counter clockwise at the same time. When the prop stops the unit is in Forward gear.<br />3. Adjust the brass barrel until the distance between the centre line of the brass barrel and the cable end guide mounting hole is EXACTLY 6 inches. (pre-1974, 5-7/8")<br />4. Re-install the shift cable onto the shift plate. DO NOT change this adjustment again.<br />5. With the control lever at full throttle in forward adjust the brass barrel to line up with the guides on the plate. DO NOT install the cable at this point.<br />6. Turn the brass barrel AWAY from the cable end guide 4 turns. Install the cable on the shift plate.<br />7. Move the control lever to the full reverse position, as the helper turns the prop slowly clockwise unitl it stops.<br />8. Check the shift cutout switch roller position. If is has moved from the centre position, adjust the brass barrel on the control cable, one turn at a time (maximum 4 turns) until the roller is in the centre position.<br />9. Secure the cables with the nyloc nuts. DO NOT tighten them onto the barrels.<br /><br /><br />Cutout switch<br /><br />The cutout switch should also be checked. The correct adjustment for the switch is to activate when the switch arm has moved 1/8". Check this with a 1/8" drill and a mulitmeter. With the key 'OFF' put the multimeter across the switch (points ignitions will have to have the points open for this) and start moving the switch arm. When the meter shows that the switch has closed, check the gap between the switch arm and the actuating lever, it should be 1/8". Bend the arm of the switch to achieve the dimension.
achris
Bump (for JB)
tommays
if i understand this correctly it is normal for the switch to cut out very quickely when shifting back to netural due to load on the gears and make contact again as soon as the load has droped it seams like it would be very hard to get out of gear if the switch did not kill the engine for that 1 or 2 tenths of a second<br /><br />tommays
JB
Moved to Engine FAQ
