Faria Cyl Head Temp Gauge
Fisher1977
I bought a Faria cylinder head temp gauge to install on my 86, 175 Mercury Black Max. It came with a sending unit, with a bracket on it. In the directions is says to remove a head bolt to install the sending unit, and reinstall the head bolt, and torque it to specs. I am not sure if I should remove a head bolt or not. Don't seem like the right thing to do. I have been a diesel mechanic for 20 years, and have never just removed 1 head bolt, and put it back in. Has anyone done this? Any other ideas on where to put the sending unit? Thanks for any help.
Faztbullet
Tweak the bracket and use the 5/1 bolts on water jacket....or better take it back and install a water pressure guage.
Silvertip
You are working on an outboard motor that has a compression ratio of somewhere around 7:1, not a diesel engine with a 23+ compression ratio. Head bolts on these motors and the torque pattern are important, but you can safely pull one and reinsert it. My preference is to install both a water pressure gauge and a temperature (water or head) gauge. Water pressure gauges tell you there is water pressure. They do not tell you the engine is cooling properly -- although they do have an overtemp sender that may or may not trigger soon enough to save a motor. But then either gauge is of little use either unless one looks at them now and then. I'm betting 80% of the boaters would head back to the dock if either gauge indicated an issue and then complain because the engine died on the way.
Fisher1977
Thanks for the replies. I appreciate the help Silvertip. You are right on, I am used to the diesels. You just don't mess with the head bolts on them, unless you are pulling the head. I agree that both a temp, and pressure gauges should be installed. Just because there is water pressure doesn't mean that a thermostat isn't stuck closed, or some other problem exists that can cause a engine to overheat. Those gauges have saved me several times over the years in my vehicle, and on my boats. I have shut the outboard down more than once, and used the trolling motor to get back to the dock.
Fisher1977
Here is one like I have.
