bigbrowndog
- May 2, 2002
- 5
Have a Faria tach attached to my 1997 Johnson 90 SPL. It doesn't move at all, so I am figuring it is either the tach or a faulty wire. Charging system works fine, and shows 12-13 volts on the Amp guage next to the tach. <br /><br />First, I cleaned all the terminals to see if it is a corroded connection. No change. Next I want to check the signal wire from the motor to see if there is a break or ? What sort of voltage or ? should be coming from the signal wire to the tach? <br /><br />Thanks<br /><br />Ty
