I have a 2000 Regal 2660 and the temperature gauge has power going to it, as the needle jumps up when the ignition is turned on. I have checked the wire from the sensor to the gauge and it is ok. I ran a jumper wire from the sensor wire to ground and turned the ignition on with no difference in the gauge reading.
So, does this verify that the gauge is defective?
Thanks,
Brian
Thanks,
Brian
