Need help! Have a rebuilt powerhead. Disconnected oil side and Rebuilt original VRO. The air motor was broken when I got the motor back after rebuild.Ran last year at a fast idle, 1500 - 1800 rpm's on a good day.I backed the rocker arm for the idle all the way back , it was not even touching the cam follower. Ran fine in gear. Found leak in the old VRO.Plunged leak lost fuel pressure immediately after. Replaced VRO and pulse limiter with new ones. Regained pressure but now it idles at 3200rpm's on the hose. Can this be a timing issue? There is a loss metal bar on top of the Throttle and Shift side arm. Could that be the problem? Is there a mechanism that kicks the rpm's down when the motor gets warm? Ready to give up!
