ScottieScott
- Nov 28, 2011
- 30
I have a 1985 Mercruiser 170, and the normal idle speed is around 900-1000 rpm's. If I adjust the idle downward, it is really rough or outright dies. I have the timing set at 4 degrees before tdc.
New Pertronix I electronic ignition, flamethrower coil. new distributor cap, new rotor, new plugs, new wires.
I don't have a problem with the idle, it doesn't sound too fast to me, but if I am not mistaken, specs for optimum performance is 600-800 rpm's.
Could it be that my rpm guage is off?
It really seems 'normal' if you listen to it, not too fast. Is this a problem?
Thanks,
Scott
Thanks,
Scott
