Re: fast idle
HI, Here's a couple items to check. That motor has six carburetors in it's design. Two of them are on one base and two are on their own base. There are a few adjustments with this set-up. There is a connector to connect one side bank to the other, then between the middle and lower carburetor there is a connector. Take the front cover off and look at the carburetor plates and see if they are all closed. If all three on one side are open, you need to adjust the top connector, if a bottom carb is open, or the top two, you need to adjust the connector between the mid and bottom carb. If all the carburetors are open, you need to adjust the screw on the throttle arm reducing the lenght of it. There should also be an adjustment screw on the link between the armature plate under the flywheel and the throttle arm. If that is out of adjustment, the engine can race up also.
