Masonk3859
- Jul 5, 2022
- 18
Hey guys, I am currently having trouble getting my 1990 Johnson 30 to fire up. When I bought the motor, I hooked it up to my battery and couldn’t get it to turn over. I rigged the solenoid up and touched it to the starter and got it to turn over, so I figured I had a bad solenoid. I ordered a new solenoid and upon installing it, it’s doing the same thing. No click and no turn over at all. The motor has the original starting switch, and I’m curious if that’s what’s giving me problems. Anyway, if this switch is bad, the oem one to replace it is around fifty dollars. I don’t mind paying, yet if I replaced it I’d want an upgrade. I was curious is anyone knew how to install a turn key start in one of these engines (and what parts to order). Also if anyone had a wiring diagram to one of these starters, that’d be great. Thanks a lot fellas. (Ignore the dirty install, this was only a test run to make sure everything was working.)
