Fd-11
merkdawg0084
Hey guys, as you know I’ve been working on an FD-11.
I know the gas mixture is 24:1. My question is I have some 50:1 for my 76 Evinrude. Could I use the 50:1 just to see if it’s going to start. Really didn’t want to mix a whole gallon of gas if it won’t run. Thx
oldboat1
No reason to do that.
You have to go to the trouble of putting it in a barrel, right? (If it fires you can easily destroy an impeller by running it dry.)
So put a half gallon of the 50:1 in your pressure tank. Add a little less than 1 1/2 oz. 2-cycle to the mix, and have at it.
merkdawg0084
Yessir I’m putting in a barrel. Been working on this motor for a friend, trying to get it running, Thank you I will do that.. Didn’t really think about adding more oil,, slipped my mind.
jimmbo
I was going to say 50:1 wouldn't hurt it but, it does use a Friction Bearing on the Crankshaft between the Cylinders, so 24: 1 it is
jimmbo
Stick with 24:1, that way if the Engine blows up, you can't be Blame Me, for saying to run 50:1
