Starcraft5834
- Jun 2, 2013
- 1,677
Hi all, bought a 1987 Imperial cuddy with galvanized Shorlandr, replaced mostly everything on trailer, new lights, surge breaks, all except axel, I kept blowing bearings and just replaced the axel too, put on 3550lb square- Venture by Tie Down on, new spindles are milled nicely to specs and fit hubs like a glove now.. the old spindle was smooth as a baby butt, bearings moving around to much I suspect,, however.... even though the pre-drilled spring centers were 62 inches spot on, my overall wheel base expanded by about 3 inches which is nice for stability but not so nice for fenders. If I put the fenders back on, they now rub on outside of tires, so off the fenders went.. Trailer frame is 4 inches, in great shape. The fenders I took off mount against the frame, connection bolt is also used by Shorlandr in this particular model to hold the leaf springs up too. That was interesting when I took off the fender bots and the spring fell too..
took fender off and put spring back up no problem,, would rather connect new fenders to frame unless you guys are aware of a fender extender system I can safely use.. otherwise will run it without... thanks for any suggestions........ js
