few problems with new four winns
seadoo97
I just bought a boat from a friend and there is a couple of problems with it.It is a 1999 190 horizon and the trim and speedo guage isnt working,not a big deal but I would like to fix it and the other is that when I turn the boat off it keeps chugging and will not die for a few seconds(sounds horrible)and last but not least it takes forever to warm up if I gun it I get a warning signal from the oil sensor flashing and beeping?All this with new oil and impellor. Please help anyone :confused: :confused:
Rhadley
Re: few problems with new four winns
Trim guage: Check sending unit on outdrive and trace continuity to guage on dash. It might need adjusting.<br />Speedometer: Probably the tube is broken or disconnected, or the pickup is not lowered. Check the pickup at the back, bottom of the boat. There is a tube coming off of it that runs to the guage on the dash.<br /><br />And you will need a manual.
Don S
What engine and drive setup do you have?
mike11374
As for the running on when you shut it off. Are you using premium fuel. When I run 87 octane mine does that. As soon as I jump to 93 it never does. Try it.
Is that a SeaDoo Horizon,..??...<br /><br />Or a Horizon Seadoo,.??....<br /><br />What's it Got for Power,.??... Arctic Cat,.??.............. :rolleyes: :D <br /><br /><br />Oh,... Btw,...... Welcome to the Forums here at iboats,.......<br />I believe the 2nd thread from the Top of this forum Explains What Info you'll have to post,.......<br />So We can Help........... :) <br /><br />Nope,... It Don't........ :( <br /><br />Anyway,..... We need to know Everything about the Engine,+ Drive that you can Tell Us,.......<br />Make,... Model,..... Serial #,..... Anything you can Find......<br />Mercruiser,..... Volvo,...... I Think it's Too New to be an OMC.......
