I am using polyester resin and I have pre-coated some pieces of wood and let sit for a few weeks before getting back into it. Other pieces I brush on the resin, then immediately add mat and wet it out. For some reason, after about 24 hours or so, I went to check on the progress and noticed that most of it set up pretty good and is not tacky but one or two spots did not and I can push the mat back onto the wood. There is clearly a gap between the wood and mat.
It is around 93 or so degrees here while I am working on it. I am using a chip brush and ''dabbing'' it on and it seems as though I am getting all of the air bubbles out. I also see other people laying mat past where they want the edge to be and grinding it off. After 24 hours (maybe more) mine is stile somewhat pliable. I could probably grind it off where I want the edge, but I do think that it would try to delaminate.
What am I doing wrong?! Is it not enough MEKP? Wetting it out to much? Not sealing the wood properly? I can take pictures and post them later on tonight, just wondering if anyone had run into these kinds of problems before.
Thanks!
Thanks!
