Re: Fiberglass hull flex
its allmost impossible to determine the rate of flex in a moving boat.....
the big thing about the repair....is that there was no water coming in !!!!.
you were putting a patch on the hull.....now...if you were stiffening the hull thats a different story.......
a lot of boats in the late 80's early 90's,were ....uhhh....welll.....mass produced......it was the more, faster, cheaper, era of boat building. a really bad time for quality. (some of the manufacturers stuck to their guns and still made a quality craft).
during this time.....a lot of manns used foam to give the hull rigidity, actually im shocked that you can get into the hull with out going thru foam. is the repair area in the ski locker?
if the repair area is the only portion of the hull that is flexing, and its really worring you......cut a 1 foot squair peice of fabric called 1708 bi ax.
cover the repair area....(after roughing the area and cleaning with aceitone).
that will give you more than enough stiffness.
it will still flex, but it will give you the peace of mind you are looking for.
(if you are wondering, how strong the fiberglass is....in an hour or two hour i will be posting a fiberglass stregnth and stiffness test on the "hull extension in progress" thread in the restoration section)
cheers
oops
