ShaneDasRip
- Feb 18, 2010
- 7
Well it happened. I took the boat out of the lake and pulled the drain plug, and at least 10 gallons of water came out of that little hole.
I got this boat a couple weeks ago. 1983 Bayliner Capri with an 85HP engine. Yeah, I know the reputation. But, it's my first boat. I've wanted a boat for 20 years now.
I've torn the engine apart, added a deck (Not replaced) polished it up. It's looking good now. I want to be able to enjoy this for a couple years before I go buy a brand new one.
https://drive.google.com/file/d/1WVh3ZZ1iMHa6Ef3lmwyyRgzDAt4l6Qgx/view?usp=sharing
The reason water came in was because this putty the previous owner came off in the water.
https://drive.google.com/file/d/1Wboh8-sgB43sjx5rsKHgfxPxZHJvVLKI/view?usp=sharing
Now it looks like this:
https://drive.google.com/file/d/1WAcJ9FzejVPbE5uG_xiscBVXDhFw0knz/view?usp=sharing
I don't want to spray Flex Seal on this. I want to fix it in a way that i don't have to worry about it for a few years.
My plan is to go to home depot, get some poly resin and CSM, sand all the edges down, glass it up, sand it, fill it, sand it, then gel coat it.
What do you think?
List of materials:
https://www.homedepot.com/p/3M-Bondo-1-qt-All-Purpose-Fiberglass-Resin-20122/202077790
https://www.homedepot.com/p/3M-Bondo-8-sq-ft-Fiberglass-Mat-20129/202077814
https://www.homedepot.com/p/3M-Bondo-41-oz-Short-Strand-Fiberglass-Filler-272/202077784
and what ever west marine has for cheapest gelcoat.
There are also numerous little chips in the gel coat. Can I use the filler in those areas then gelcoat over them?
https://drive.google.com/file/d/1W6TC_gioBYUGwU0qaf5NZQ0W4gVKXqBR/view?usp=sharing
Questions I am asking the community:
Does that sound like an OK plan?
Am I OK using that resin? I've read it's OK as long as I gelcoat it.
When I use CSM, Do I use the biggest piece first then taper down to the smallest? or should I build up the edge with small ones, then use large ones to round out the corner again?
Do I want to finish, start, or even use glass cloth? https://www.homedepot.com/p/3M-Bondo-8-sq-ft-Fiberglass-Cloth-20128/202077813
What do you think?
List of materials:
