Re: Fiberglass hull repair
Welcome to iboats.
Well you have many choices.......
Fiberglass then gel coat repair if it shows and it bothers you.... OR
Marine Tex which you can not do a gel coat repair over and will show as a white or gray repair depending on the color your purchase....
OR
Bondo makes a marine epoxy that is a stick and you cut a chunk off knead it in your hand and push it into the hole... this stuff can cure under water too
I actually carry one for emergencies on the water.
