Re: Fiberglass or aluminum?
Aluminum is lighter and stronger, and requires less power. If you are going to be fishing shallow water, aluminum is the way to go, as it has a shallower draft and if you bump a rock its no big deal. I have a glass boat, but if I came across an aluminum hull I would switch in a heart beat (Someone has to die and will you an aluminum hull around here). You have not said what size, type of fishing, budget etc, all of which is a factor. Hull design will be based on the water you will use it on. If the water is rough, a V bottom is what you want. If the water is mostly calm, a more flatter bottom will work. Just remember, a flat bottom does not need as much power as a V bottom to plane.
