Fiberglass pontoon seal to floor?
kryan2
Suggestions on what to put between the floor and fiberglass pontoon to seal it all up.....
kryan2
replacing 1 sheet but pulling up all boards to reseal..
ahicks
Have you considered installing a hatch on each side to monitor water, and possibly service a bilge pump placed under each?
kryan2
there is a bilge in each toon in the rear. Hatch for sure. I need something between the glass and wood. There is currently something black and sticky between there now....
ahicks
So the black sticky stuff will be remove prior to the new attempt, or must the new "stuff" be compatible with what's there now?
DECK SWABBER 58
Lexel caulk. Interesting...have never seen a pontoon boat with fiberglass pontoons.
kryan2
i would like to clean all the "old" stuff off and put something brand new.
Grub54891
It is a rather interesting design, At the point it's at, I'd continue removing the decking, and get rid of all the sticky goo that is on there now. And replace all he wood.
ahicks
Maybe try to come up with a design that's more about gasket, less about sealant? I don't know what you would use, but if you could come up with something soft and pliable, it might last longer than a sealant, and be WAY less hassle to replace.
Bayou Dave
You should be able to find it locally at a RV supply or mobile home supply. Possibly at Lowes or HD.
