Fiberglass pontoon turns into cooler or storage?
kryan2
Just picked up a 24' pontoon with fiberglass toons. Once I take off the deck sheets wouldn't you think it would be possible to "dig" out some of the foam from each toon and turn it into a "under deck" cooler? Hatch on the decking would give access?
Thoughts??
alldodge
Thoughts??
You could but I wouldn't recommended it. If you ever puncher a hole and crack in the tube, it will fill fast. Kind of like punch a hole in a beer can then pop the top. Gravity will empty the can real quick, but the tube would be under pressure from the water around it. They do hollow out a tri-toon for storage, but it will stay afloat on two of the three
Ayuh,.... It "Looks" home made,....
Are ya sure there's foam in the 'toons,..??
kryan2
Yep... all foam inside the back wood from the deck isn't bolted down so I could see inside of them that's how I know there's build pumps in each one
