Fiberglassing Corners?
CaptMick
Is it true that you should round off the corners that you are going to fiberglass instead of glassing a 90 degree corner. I'm not sure if I have heard this or not. I am currently glassing a transom and was wondering about the outside 90's on the bilge side.
flashback
Re: Fiberglassing Corners?
capt, It is virtually impossible to create square corners with fiberglass. You must radius the corners at least 1/8 to 1/4 inch. 1/4 being the best.
